Hi! Everyone! I’m new here.
I have a problem when i set exterior shade plate schedule. I hope the shade only work in summer to calculate the energy consumption and with no shade in winter. But the result seems it works both in summer and winter.
here is my gh file20190620 nenghaofengchao xiugaicanshu3-1zy1开孔率0.gh (1.2 MB)
nenghaomoxing fengchao.3dm (176.9 KB)
the location is China Hangzhou
i have confirm the schedule work well. But when it links to the EPTransSchedule, the result is the same
Hi,@wtlodger You grasshopper definition is so complex. According to your problem. I do a simple example.
Here is the shade schedule:
The result of a model without shade and a model with shade only in summer
Here are the two results.
with tree only in summer.gh (679.5 KB)
Thank you very much. I have solved the problem from your example. The point is how to understand EPTransSchedule. When the value set to 1, it means the shade is transparent.
