The orientation related to North can be set up in “Honeybee_ Run Energy Simulation” components, but I do not find how to set up the North orientation for “HBZones”, such as in “Honeybee_Set EnergyPlus Zone Thresholds”.
If I set up the North orientation in “Honeybee_ Run Energy Simulation”, but do not (or cannot) set up North orientation for “HBZones”, some calculation result will be not correct.
Your solution can be applied to c, it will impact the component which is follow the “Honeybee_ Run Energy Simulation” component(downstream), it cannot impact the other components(upstream).
I try to find how to set up the the North orientation for HBZones before “Honeybee_ Run Energy Simulation” component.
Does “North” in Ladybug refer to magnetic north or to true north.
For example, North_ is a possible input into the LB_SkyMatrix component.
Thank you for answering.
