Assuming that you are using Rhino 6, I just pushed an updated version of the installer to food4rhino that should fix the issue with that component. So just uninstall and reinstall using the latest installer from food4rhino and you should be set.
Let me know if it does not solve it and thanks again!
Hi @chris!
Thank you very much for your reply. Yes, I use Rhino 6!
I tried as you told me above and the heatmap component came back to work, but the some others did not.
I’ll leave you an example below, if you want I can try them all and see which ones are “red” due to lack of the specific module and give you a single screenshot…
Thank you very much for your support. Always great.
See you soon
