I try to run a URBANopt (version 0.10.0) simulation using the core library of Dragonfly from a script. The core libraries of LBT (lbt-ladybug, lbt-honeybee and lbt-dragonfly) were installed in a conda environment (python 3.11.5). I have installed very recently the last version of all the dependencies provided by the free Pollination single-click installer. So, I suppose this is the last version of it (1.7.0… not really sure how to check).
My whole script works well until I explicitly run URBANopt with the function “run.run_urbanopt()”. Before that, I generated successfully the necessary files (feature_geojson, scenario CSV file and hb workflow OSW file) with the dragonfly functions “writer.model_to_urbanopt()”, “run.prepare_urbanopt_folder()” and “run.base_boneybee_osw()”.
So, as soon as I use the run.run_urbanopt() function, the function generates empty results. For each of the building in the urban model, I receive the following errors:
First:
run_dir ‘c:/uoSim/UOfiles/run/honeybee_scenario/05158446_4/’ does not exist, simulation dir ‘c:/uoSim/UOfiles/run/honeybee_scenario/05158446_4/’ out of date
simulation_dir c:/uoSim/UOfiles/run/honeybee_scenario/05158446_4/ is out of date, regenerating input files
Second:
finished_job_path ‘c:/uoSim/UOfiles/run/honeybee_scenario/05158446_4/finished.job’ does not exist, simulation dir ‘c:/uoSim/UOfiles/run/honeybee_scenario/05158446_4/’ out of date
Third:
SYSTEM CALL:
C:/URBANopt-cli-0.10.0/OpenStudio/bin/openstudio.exe --verbose --bundle ‘c:/uoSim/UOfiles/Gemfile’ --bundle_path ‘c:/uoSim/UOfiles/.bundle/install/’ run -w ‘c:/uoSim/UOfiles/run/honeybee_scenario/05158446_4/in.osw’ 2>&1 > “c:/uoSim/UOfiles/run/honeybee_scenario/05158446_4/in.osw.log”
Fourth:
DONE, result = false
Error running command: ‘C:/URBANopt-cli-0.10.0/OpenStudio/bin/openstudio.exe --verbose --bundle ‘c:/uoSim/UOfiles/Gemfile’ --bundle_path ‘c:/uoSim/UOfiles/.bundle/install/’ run -w ‘c:/uoSim/UOfiles/run/honeybee_scenario/05158446_4/in.osw’ 2>&1 > “c:/uoSim/UOfiles/run/honeybee_scenario/05158446_4/in.osw.log”’
stdout:
stderr:
Finally, I get the information the simulation failed for all buildings with this message:
FAILED SIMULATION IDs: 05158446_4,05158446_9, etc. (all the other building IDs)
Besides, I checked the log file for one of the building (in.osw.log) and I have the following content stating for example that some of the gems were not activated due to an error. Here is the log completely:
I, [2023-11-07T20:50:42.023043 #3560] INFO – : CLI Parsed Inputs: [“–verbose”, “–bundle”, “c:/uoSim/UOfiles/Gemfile”, “–bundle_path”, “c:/uoSim/UOfiles/.bundle/install/”] “run” [“-w”, “c:/uoSim/UOfiles/run/honeybee_scenario/05158446_4/in.osw”]
D, [2023-11-07T20:50:42.023121 #3560] DEBUG – : Main arguments are [“–verbose”, “–bundle”, “c:/uoSim/UOfiles/Gemfile”, “–bundle_path”, “c:/uoSim/UOfiles/.bundle/install/”]
D, [2023-11-07T20:50:42.023133 #3560] DEBUG – : Sub-command is run
D, [2023-11-07T20:50:42.023142 #3560] DEBUG – : Sub-arguments are [“-w”, “c:/uoSim/UOfiles/run/honeybee_scenario/05158446_4/in.osw”]
D, [2023-11-07T20:50:42.023223 #3560] DEBUG – : Parsing main_args [“–verbose”, “–bundle”, “c:/uoSim/UOfiles/Gemfile”, “–bundle_path”, “c:/uoSim/UOfiles/.bundle/install/”]
I, [2023-11-07T20:50:42.023261 #3560] INFO – : Setting BUNDLE_GEMFILE to c:/uoSim/UOfiles/Gemfile
I, [2023-11-07T20:50:42.023341 #3560] INFO – : Setting BUNDLE_PATH to c:/uoSim/UOfiles/.bundle/install/
I, [2023-11-07T20:50:42.023365 #3560] INFO – : Bundle activated but ENV[‘BUNDLE_WITHOUT’] is not set
I, [2023-11-07T20:50:42.023371 #3560] INFO – : Setting BUNDLE_WITHOUT to ‘test’
D, [2023-11-07T20:50:42.738102 #3560] DEBUG – : Adding dependency on jaro_winkler ‘~> 1.5.4’
D, [2023-11-07T20:50:42.738177 #3560] DEBUG – : Adding dependency on pycall ‘~> 1.2.1’
D, [2023-11-07T20:50:42.738197 #3560] DEBUG – : Adding dependency on sqlite3 ‘~> 1.3.13.20180326210955’
D, [2023-11-07T20:50:42.738214 #3560] DEBUG – : Adding dependency on tbd ‘~> 3.2.2’
D, [2023-11-07T20:50:42.738229 #3560] DEBUG – : Adding dependency on addressable ‘~> 2.8.1’
D, [2023-11-07T20:50:42.738243 #3560] DEBUG – : Adding dependency on ansi ‘~> 1.5.0’
D, [2023-11-07T20:50:42.738256 #3560] DEBUG – : Adding dependency on ast ‘~> 2.4.2’
D, [2023-11-07T20:50:42.738270 #3560] DEBUG – : Adding dependency on bcl ‘~> 0.7.1’
D, [2023-11-07T20:50:42.738312 #3560] DEBUG – : Adding dependency on builder ‘~> 3.2.4’
D, [2023-11-07T20:50:42.738328 #3560] DEBUG – : Adding dependency on bundler ‘~> 2.1.4’
D, [2023-11-07T20:50:42.738341 #3560] DEBUG – : Adding dependency on docile ‘~> 1.4.0’
D, [2023-11-07T20:50:42.738354 #3560] DEBUG – : Adding dependency on faraday ‘~> 1.0.1’
D, [2023-11-07T20:50:42.738367 #3560] DEBUG – : Adding dependency on git ‘~> 1.12.0’
D, [2023-11-07T20:50:42.738381 #3560] DEBUG – : Adding dependency on json-schema ‘~> 2.7.0’
D, [2023-11-07T20:50:42.738394 #3560] DEBUG – : Adding dependency on macaddr ‘~> 1.7.2’
D, [2023-11-07T20:50:42.738407 #3560] DEBUG – : Adding dependency on matrix ‘~> 0.4.2’
D, [2023-11-07T20:50:42.738442 #3560] DEBUG – : Adding dependency on minitar ‘~> 0.9’
D, [2023-11-07T20:50:42.738457 #3560] DEBUG – : Adding dependency on minitest ‘~> 5.14.4’
D, [2023-11-07T20:50:42.738470 #3560] DEBUG – : Adding dependency on minitest-reporters ‘~> 1.4.3’
D, [2023-11-07T20:50:42.738492 #3560] DEBUG – : Adding dependency on msgpack ‘~> 1.4.2’
D, [2023-11-07T20:50:42.738506 #3560] DEBUG – : Adding dependency on multipart-post ‘~> 2.3.0’
D, [2023-11-07T20:50:42.738532 #3560] DEBUG – : Adding dependency on octokit ‘~> 4.18.0’
D, [2023-11-07T20:50:42.738549 #3560] DEBUG – : Adding dependency on oga ‘~> 3.2’
D, [2023-11-07T20:50:42.738572 #3560] DEBUG – : Adding dependency on openstudio-extension ‘~> 0.6.0’
D, [2023-11-07T20:50:42.738585 #3560] DEBUG – : Adding dependency on openstudio-standards ‘~> 0.4.0’
D, [2023-11-07T20:50:42.738609 #3560] DEBUG – : Adding dependency on openstudio-workflow ‘~> 2.3.1’
D, [2023-11-07T20:50:42.738623 #3560] DEBUG – : Adding dependency on openstudio_measure_tester ‘~> 0.3.2’
D, [2023-11-07T20:50:42.738637 #3560] DEBUG – : Adding dependency on oslg ‘~> 0.2.6’
D, [2023-11-07T20:50:42.738660 #3560] DEBUG – : Adding dependency on osut ‘~> 0.2.8’
D, [2023-11-07T20:50:42.738673 #3560] DEBUG – : Adding dependency on parallel ‘~> 1.19.1’
D, [2023-11-07T20:50:42.738698 #3560] DEBUG – : Adding dependency on parser ‘~> 3.2.2.1’
D, [2023-11-07T20:50:42.738714 #3560] DEBUG – : Adding dependency on public_suffix ‘~> 5.0.1’
D, [2023-11-07T20:50:42.738727 #3560] DEBUG – : Adding dependency on rainbow ‘~> 3.1.1’
D, [2023-11-07T20:50:42.738741 #3560] DEBUG – : Adding dependency on rake ‘~> 13.0.6’
D, [2023-11-07T20:50:42.738754 #3560] DEBUG – : Adding dependency on rchardet ‘~> 1.8.0’
D, [2023-11-07T20:50:42.738777 #3560] DEBUG – : Adding dependency on regexp_parser ‘~> 2.8.0’
D, [2023-11-07T20:50:42.738814 #3560] DEBUG – : Adding dependency on rexml ‘~> 3.2.5’
D, [2023-11-07T20:50:42.738829 #3560] DEBUG – : Adding dependency on rubocop ‘~> 1.15.0’
D, [2023-11-07T20:50:42.738843 #3560] DEBUG – : Adding dependency on rubocop-ast ‘~> 1.28.0’
D, [2023-11-07T20:50:42.738867 #3560] DEBUG – : Adding dependency on rubocop-checkstyle_formatter ‘~> 0.4.0’
D, [2023-11-07T20:50:42.738882 #3560] DEBUG – : Adding dependency on rubocop-performance ‘~> 1.11.5’
D, [2023-11-07T20:50:42.738907 #3560] DEBUG – : Adding dependency on ruby-ll ‘~> 2.1.2’
D, [2023-11-07T20:50:42.738922 #3560] DEBUG – : Adding dependency on ruby-ole ‘~> 1.2.12.2’
D, [2023-11-07T20:50:42.738947 #3560] DEBUG – : Adding dependency on ruby-progressbar ‘~> 1.13.0’
D, [2023-11-07T20:50:42.738961 #3560] DEBUG – : Adding dependency on rubyzip ‘~> 2.3.2’
D, [2023-11-07T20:50:42.738974 #3560] DEBUG – : Adding dependency on sawyer ‘~> 0.8.2’
D, [2023-11-07T20:50:42.738987 #3560] DEBUG – : Adding dependency on simplecov ‘~> 0.18.5’
D, [2023-11-07T20:50:42.739013 #3560] DEBUG – : Adding dependency on simplecov-html ‘~> 0.12.3’
D, [2023-11-07T20:50:42.739028 #3560] DEBUG – : Adding dependency on spreadsheet ‘~> 1.2.9’
D, [2023-11-07T20:50:42.739041 #3560] DEBUG – : Adding dependency on systemu ‘~> 2.6.5’
D, [2023-11-07T20:50:42.739053 #3560] DEBUG – : Adding dependency on topolys ‘~> 0.6.1’
D, [2023-11-07T20:50:42.739078 #3560] DEBUG – : Adding dependency on unicode-display_width ‘~> 2.4.2’
D, [2023-11-07T20:50:42.739093 #3560] DEBUG – : Adding dependency on uuid ‘~> 2.3.9’
D, [2023-11-07T20:50:42.739125 #3560] DEBUG – : Adding dependency on yamler ‘~> 0.1.0’
D, [2023-11-07T20:50:42.739141 #3560] DEBUG – : Adding dependency on zliby ‘~> 0.0.5’
D, [2023-11-07T20:50:42.826563 #3560] DEBUG – : Processing 55 activation requests
D, [2023-11-07T20:50:42.851951 #3560] DEBUG – : Activating gem :/ruby/2.7.0/specifications/bundler-2.1.4.gemspec
I, [2023-11-07T20:50:42.852087 #3560] INFO – : Temporarily replacing arch ‘x64-mswin64_140’ with ‘x64-mingw32’ for Bundle
I, [2023-11-07T20:50:45.068733 #3560] INFO – : without_groups = test
I, [2023-11-07T20:50:45.068767 #3560] INFO – : g = default
I, [2023-11-07T20:50:45.068784 #3560] INFO – : Bundling with groups [default]
I, [2023-11-07T20:50:45.816971 #3560] INFO – : Specs to be included [rake,public_suffix,addressable,ansi,ast,builder,multipart-post,faraday,minitar,rchardet,git,minitest,ruby-progressbar,minitest-reporters,parallel,parser,rainbow,regexp_parser,rexml,rubocop-ast,unicode-display_width,rubocop,rubocop-checkstyle_formatter,rubocop-performance,docile,simplecov-html,simplecov,openstudio_measure_tester,rubyzip,ruby-ole,spreadsheet,systemu,macaddr,uuid,yamler,zliby,bcl,bundler,json_pure,sawyer,octokit,openstudio-workflow,openstudio-extension,json-schema,oslg,osut,matrix,topolys,tbd,openstudio-standards,honeybee-openstudio,openstudio-calibration,openstudio-common-measures,openstudio-ee,openstudio-geb,openstudio-load-flexibility-measures,openstudio-model-articulation,urbanopt-core,urbanopt-geojson,urbanopt-reporting]
I, [2023-11-07T20:50:48.298954 #3560] INFO – : Restoring arch ‘x64-mswin64_140’
D, [2023-11-07T20:50:48.299170 #3560] DEBUG – : Activating gem :/ruby/2.7.0/bundler/specifications/jaro_winkler-1.5.4.gemspec
D, [2023-11-07T20:50:48.299574 #3560] DEBUG – : Activating gem :/ruby/2.7.0/bundler/specifications/pycall-1.2.1.gemspec
D, [2023-11-07T20:50:48.299979 #3560] DEBUG – : Activating gem :/ruby/2.7.0/bundler/specifications/sqlite3-1.3.13.20180326210955.gemspec
D, [2023-11-07T20:50:48.300322 #3560] DEBUG – : Activating gem :/ruby/2.7.0/specifications/public_suffix-5.0.1.gemspec
E, [2023-11-07T20:50:48.300419 #3560] ERROR – : Error activating gem :/ruby/2.7.0/specifications/public_suffix-5.0.1.gemspec
D, [2023-11-07T20:50:48.300727 #3560] DEBUG – : Activating gem :/ruby/2.7.0/specifications/addressable-2.8.1.gemspec
D, [2023-11-07T20:50:48.300775 #3560] DEBUG – : Activating gem :/ruby/2.7.0/specifications/json-schema-2.7.0.gemspec
D, [2023-11-07T20:50:48.300816 #3560] DEBUG – : Activating gem :/ruby/2.7.0/specifications/oslg-0.2.6.gemspec
E, [2023-11-07T20:50:48.300859 #3560] ERROR – : Error activating gem :/ruby/2.7.0/specifications/oslg-0.2.6.gemspec
D, [2023-11-07T20:50:48.300914 #3560] DEBUG – : Activating gem :/ruby/2.7.0/specifications/osut-0.2.8.gemspec
E, [2023-11-07T20:50:48.300964 #3560] ERROR – : Error activating gem :/ruby/2.7.0/specifications/osut-0.2.8.gemspec
D, [2023-11-07T20:50:48.301005 #3560] DEBUG – : Activating gem :/ruby/2.7.0/specifications/matrix-0.4.2.gemspec
D, [2023-11-07T20:50:48.301043 #3560] DEBUG – : Activating gem :/ruby/2.7.0/specifications/topolys-0.6.1.gemspec
E, [2023-11-07T20:50:48.301076 #3560] ERROR – : Error activating gem :/ruby/2.7.0/specifications/topolys-0.6.1.gemspec
D, [2023-11-07T20:50:48.301119 #3560] DEBUG – : Activating gem :/ruby/2.7.0/bundler/specifications/tbd-3.2.2.gemspec
E, [2023-11-07T20:50:48.301158 #3560] ERROR – : Error activating gem :/ruby/2.7.0/bundler/specifications/tbd-3.2.2.gemspec
D, [2023-11-07T20:50:48.301197 #3560] DEBUG – : Activating gem :/ruby/2.7.0/specifications/ansi-1.5.0.gemspec
D, [2023-11-07T20:50:48.301259 #3560] DEBUG – : Activating gem :/ruby/2.7.0/specifications/ast-2.4.2.gemspec
D, [2023-11-07T20:50:48.301298 #3560] DEBUG – : Activating gem :/ruby/2.7.0/specifications/zliby-0.0.5.gemspec
D, [2023-11-07T20:50:48.301335 #3560] DEBUG – : Activating gem :/ruby/2.7.0/specifications/yamler-0.1.0.gemspec
D, [2023-11-07T20:50:48.301373 #3560] DEBUG – : Activating gem :/ruby/2.7.0/specifications/systemu-2.6.5.gemspec
D, [2023-11-07T20:50:48.301446 #3560] DEBUG – : Activating gem :/ruby/2.7.0/specifications/macaddr-1.7.2.gemspec
D, [2023-11-07T20:50:48.301485 #3560] DEBUG – : Activating gem :/ruby/2.7.0/specifications/uuid-2.3.9.gemspec
D, [2023-11-07T20:50:48.301526 #3560] DEBUG – : Activating gem :/ruby/2.7.0/specifications/ruby-ole-1.2.12.2.gemspec
D, [2023-11-07T20:50:48.301574 #3560] DEBUG – : Activating gem :/ruby/2.7.0/specifications/spreadsheet-1.2.9.gemspec
D, [2023-11-07T20:50:48.301633 #3560] DEBUG – : Activating gem :/ruby/2.7.0/specifications/rubyzip-2.3.2.gemspec
D, [2023-11-07T20:50:48.301672 #3560] DEBUG – : Activating gem :/ruby/2.7.0/specifications/rexml-3.2.5.gemspec
D, [2023-11-07T20:50:48.301712 #3560] DEBUG – : Activating gem :/ruby/2.7.0/specifications/simplecov-html-0.12.3.gemspec
D, [2023-11-07T20:50:48.301752 #3560] DEBUG – : Activating gem :/ruby/2.7.0/specifications/docile-1.4.0.gemspec
D, [2023-11-07T20:50:48.301791 #3560] DEBUG – : Activating gem :/ruby/2.7.0/specifications/simplecov-0.18.5.gemspec
D, [2023-11-07T20:50:48.301851 #3560] DEBUG – : Activating gem :/ruby/2.7.0/specifications/unicode-display_width-2.4.2.gemspec
D, [2023-11-07T20:50:48.301902 #3560] DEBUG – : Activating gem :/ruby/2.7.0/specifications/ruby-progressbar-1.13.0.gemspec
D, [2023-11-07T20:50:48.301943 #3560] DEBUG – : Activating gem :/ruby/2.7.0/specifications/parser-3.2.2.1.gemspec
E, [2023-11-07T20:50:48.301978 #3560] ERROR – : Error activating gem :/ruby/2.7.0/specifications/parser-3.2.2.1.gemspec
D, [2023-11-07T20:50:48.302019 #3560] DEBUG – : Activating gem :/ruby/2.7.0/specifications/rubocop-ast-1.28.0.gemspec
E, [2023-11-07T20:50:48.302069 #3560] ERROR – : Error activating gem :/ruby/2.7.0/specifications/rubocop-ast-1.28.0.gemspec
D, [2023-11-07T20:50:48.302111 #3560] DEBUG – : Activating gem :/ruby/2.7.0/specifications/regexp_parser-2.8.0.gemspec
E, [2023-11-07T20:50:48.302142 #3560] ERROR – : Error activating gem :/ruby/2.7.0/specifications/regexp_parser-2.8.0.gemspec
D, [2023-11-07T20:50:48.302183 #3560] DEBUG – : Activating gem :/ruby/2.7.0/specifications/rainbow-3.1.1.gemspec
D, [2023-11-07T20:50:48.302232 #3560] DEBUG – : Activating gem :/ruby/2.7.0/specifications/parallel-1.19.1.gemspec
E, [2023-11-07T20:50:48.302265 #3560] ERROR – : Error activating gem :/ruby/2.7.0/specifications/parallel-1.19.1.gemspec
D, [2023-11-07T20:50:48.302308 #3560] DEBUG – : Activating gem :/ruby/2.7.0/specifications/rubocop-1.15.0.gemspec
D, [2023-11-07T20:50:48.302362 #3560] DEBUG – : Activating gem :/ruby/2.7.0/specifications/rubocop-checkstyle_formatter-0.4.0.gemspec
D, [2023-11-07T20:50:48.302404 #3560] DEBUG – : Activating gem :/ruby/2.7.0/specifications/rubocop-performance-1.11.5.gemspec
D, [2023-11-07T20:50:48.302451 #3560] DEBUG – : Activating gem :/ruby/2.7.0/specifications/rake-13.0.6.gemspec
D, [2023-11-07T20:50:48.302495 #3560] DEBUG – : Activating gem :/ruby/2.7.0/specifications/builder-3.2.4.gemspec
D, [2023-11-07T20:50:48.302549 #3560] DEBUG – : Activating gem :/ruby/2.7.0/specifications/minitest-5.14.4.gemspec
D, [2023-11-07T20:50:48.302602 #3560] DEBUG – : Activating gem :/ruby/2.7.0/specifications/minitest-reporters-1.4.3.gemspec
D, [2023-11-07T20:50:48.302642 #3560] DEBUG – : Activating gem :/ruby/2.7.0/specifications/rchardet-1.8.0.gemspec
D, [2023-11-07T20:50:48.302695 #3560] DEBUG – : Activating gem :/ruby/2.7.0/specifications/git-1.12.0.gemspec
D, [2023-11-07T20:50:48.302740 #3560] DEBUG – : Activating gem :/ruby/2.7.0/specifications/openstudio_measure_tester-0.3.2.gemspec
D, [2023-11-07T20:50:48.302780 #3560] DEBUG – : Activating gem :/ruby/2.7.0/specifications/minitar-0.9.gemspec
D, [2023-11-07T20:50:48.302820 #3560] DEBUG – : Activating gem :/ruby/2.7.0/specifications/multipart-post-2.3.0.gemspec
D, [2023-11-07T20:50:48.302880 #3560] DEBUG – : Activating gem :/ruby/2.7.0/specifications/faraday-1.0.1.gemspec
D, [2023-11-07T20:50:48.302919 #3560] DEBUG – : Activating gem :/ruby/2.7.0/specifications/bcl-0.7.1.gemspec
D, [2023-11-07T20:50:48.302933 #3560] DEBUG – : Activating gem :/ruby/2.7.0/specifications/bundler-2.1.4.gemspec
D, [2023-11-07T20:50:48.302972 #3560] DEBUG – : Activating gem :/ruby/2.7.0/specifications/msgpack-1.4.2.gemspec
D, [2023-11-07T20:50:48.303284 #3560] DEBUG – : Activating gem :/ruby/2.7.0/specifications/sawyer-0.8.2.gemspec
D, [2023-11-07T20:50:48.303329 #3560] DEBUG – : Activating gem :/ruby/2.7.0/specifications/octokit-4.18.0.gemspec
D, [2023-11-07T20:50:48.303376 #3560] DEBUG – : Activating gem :/ruby/2.7.0/specifications/ruby-ll-2.1.2.gemspec
D, [2023-11-07T20:50:48.305567 #3560] DEBUG – : Activating gem :/ruby/2.7.0/specifications/oga-3.2.gemspec
D, [2023-11-07T20:50:48.306021 #3560] DEBUG – : Activating gem :/ruby/2.7.0/specifications/openstudio-workflow-2.3.1.gemspec
D, [2023-11-07T20:50:48.306075 #3560] DEBUG – : Activating gem :/ruby/2.7.0/specifications/openstudio-extension-0.6.0.gemspec
E, [2023-11-07T20:50:48.306133 #3560] ERROR – : Error activating gem :/ruby/2.7.0/specifications/openstudio-extension-0.6.0.gemspec
D, [2023-11-07T20:50:48.306186 #3560] DEBUG – : Activating gem :/ruby/2.7.0/specifications/openstudio-standards-0.4.0.gemspec
D, [2023-11-07T20:50:48.306764 #3560] DEBUG – : Invoking command class: Run [“-w”, “c:/uoSim/UOfiles/run/honeybee_scenario/05158446_4/in.osw”]
I, [2023-11-07T20:50:48.306799 #3560] INFO – : Run, sub_argv = [“-w”, “c:/uoSim/UOfiles/run/honeybee_scenario/05158446_4/in.osw”]
D, [2023-11-07T20:50:48.309194 #3560] DEBUG – : Run command: [] {:debug=>false, :no_simulation=>false, :osw_path=>“c:/uoSim/UOfiles/run/honeybee_scenario/05158446_4/in.osw”, :post_process=>false, :ep_json=>false, :ft_options=>{}, :show_stdout=>false, :add_timings=>false, :style_stdout=>false}
[openstudio.XMLValidator] <-1> Treating schema as a regular XSD
[openstudio.XMLValidator] <1> xsdValidate.parseFileError: XML error 17.1871: Element ‘descrption’: This element is not expected. Expected is one of ( short_name, description, type ).
at c:/uoSim/UOfiles/.bundle/install/ruby/2.7.0/gems/urbanopt-reporting-0.8.0/lib/measures/default_feature_reports/measure.xml:42
[utilities.bcl.BCLXML] <0> Failed to validate measure.xml at c:/uoSim/UOfiles/.bundle/install/ruby/2.7.0/gems/urbanopt-reporting-0.8.0/lib/measures/default_feature_reports/measure.xml
[ApplicationPathHelpers] <-2> getOpenStudioModule, szPath = ‘C:\URBANopt-cli-0.10.0\OpenStudio\bin\openstudiolib.dll’
[PathHelpers] <-2> completeAndNormalize: result = C:/URBANopt-cli-0.10.0/OpenStudio/bin/openstudiolib.dll
[ApplicationPathHelpers] <-2> getOpenStudioModule, found ‘C:/URBANopt-cli-0.10.0/OpenStudio/bin/openstudiolib.dll’
[OpenStudio.Measure] <0> OSRunner is deprecated, use OpenStudio::Measure::OSRunner instead.
[20:50:49.233879 DEBUG] Path for the OSW: c:/uoSim/UOfiles/run/honeybee_scenario/05158446_4/in.osw
[20:50:49.233973 DEBUG] Initializing run method
[20:50:49.324903 DEBUG] Beginning run
[20:50:49.600864 ERROR] Found error in state ‘initialization’ with message [“Weather file ‘UOfiles/meteo/CAN_QC_Montreal-Trudeau.Intl.AP.716270_CWEC.epw’ specified but cannot be found:c:/uoSim/UOfiles/.bundle/install/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/jobs/run_initialization.rb:192:in `perform’\nc:/uoSim/UOfiles/.bundle/install/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:291:in `step’\nc:/uoSim/UOfiles/.bundle/install/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:233:in `run’\n:/openstudio_cli.rb:1187:in `execute’\n:/openstudio_cli.rb:817:in `execute’\n:/openstudio_cli.rb:1984:in `‘\neval:188:in `eval’\neval:188:in `require_embedded_absolute’\neval:173:in `block in require_embedded’\neval:167:in `each’\neval:167:in `require_embedded’\neval:126:in `require’\neval:3:in `'”]}
Any idea of what could be the problem?
Thanks a lot in advance,
Benoit
