I downloaded the Calculate_ASE_For_Leed file and I’m trying to configure a new geometry.
Unfortunatly the Ladybug_Mesh Threshold Selector Component do this error: Attempted to divide by zero.
Thanks a lot @chris ,
problem solved.
To do this work I started importing an .idf file, with a select item I selected the room and then I made a bake to have the sueprfici without the windows, to divide and assign as context or test geometry. I will try to automate everything with Gh. Thank you so much again!
