Hi, I am simulating the energy consumption in the small residential dwellings in a tropical climate. The model and results look fair when I have a glazing surface only on one wall of the house. However, when I add even a minor glazing surface in the different wall the cooling energy consumption increase nearly two-fold. Any ideas on how to overcome this issue?
In the attachment you can find the model, I am using the visualarq plugin which helps with the parametrical design of the house, however, I also internalize the example structure into the model. I will be grateful for any feedback.
House simple_rectangle shape.gh (841.8 KB)
