Hi
I Create Honeybee Rooms from solids, I want Deconstruct geometry Like the Legacy version but I can’t.
What is the problem?
Of course, I know that HB Face gets Brep input, but there is no solution for this?
This problem did not exist in the Legacy version.
Error.gh (21.8 KB)
Hi
No, I attached the file but like this.
Hi @Mohammad.hakim.a
Would you mind me asking what you are trying to do with the face? It seems you alread have the face when exploding the tree, so no need to create a HB surface, because it is already there.
If you want to visualize the surface you might want to use the “HB Visualize All”
Hi @ncatunda @Erikbeeren
I don’t want to visualize,I want to be able to manually configure each face after Create Honeybee Rooms from solids. This was not a problem in the previous version
Hi @Mohammad.hakim.a,
The problem with your model is that you that you try to input “Honeybey faces” in a node which requires “Grasshopper/Rhino surfaces”. In the exemple below you can see how to get things working.
