This is how I started my workflow with the following script where the file I am using is an .OSM model exported from Revit via Pollination, and it is a valid model.
I then identified the material for each type, made an HB model and connected it to the HB Simulation Output; however, it keeps showing an error message stating that the rooms are not conditioned.
I also tried adjusting the rooms to be conditioned using the OpenStudio application, but the same error message persists. I’m not sure what I need to adjust to resolve this issue.
Another problem arises when I connect the model to the HB Model to OSM component, where I encounter the following message: “1. ** Severe ** DetermineShadowingCombinations: There are 189 surfaces which are casting surfaces and are non-convex.”
