I have got a problem with HoneyBee_RADParameters component, because when i change the default inputs (like ab, ad, as, …), even if the output “out” shows the inputs i have changed, during the simulation i can see from the black window of the radiance simulation that i still have default values, excepting for ab that is changed.
I have also checked the “range” of the values according to radiance and the values i put are in the domain so i may exclude that problem.
Do you know where is the problem? What do you suggest?
I hope you´ll help me to solve this problem because it should be a way to decrease the time to run a daylight simulation!!!
What type of analysis are you running with Honeybee? ImageBased, GridBased, annual?
I did a quick test for imageBased analysis and the file is generated correctly. To check the parameters you can open the studyFolder (it’s one of the outputs of run daylight analysis component.) and check *.bat files. There is a rpict or rtrace line that you can see all the parameters listed. Mine is:
It happens the same to me. When I run Daylight Factor analysis the only parameter that changes is the “ab”. All the other parameters are fixed. Claudio
I add some screenshots as well. Even with the preset for the low quality:
You can see that in the read me panel it says that there are some preset values but then when the simulation run, only the ab value is the right one and can be customized: ad 1000, ar 300 and aa 0.1.
Ok! That helps. It’s because Honeybee’s internal check of the parameters to make sure the quality meets the minimum accuracy. If you check readMe! on runDaylight component you’ll see something like this:
If you change the parameters to be more than minimum then you will see the change in the batch file. Check this discussion if you like to stop the internal check.
I followed the other discussion and i did what you suggested (to put # before the sentence hb_writeRADAUX.checkInputParametersForGridBasedAnalysis) but i still have that problem. I still have other values in the .bat files
Hello everyone.I have about the same problem.I am trying to run daylight factor simulation.but after running nothing happen and all grids show zero daylight.What should be the reason?I will be thank full for answer.daylight factor.3dm (229.1 KB)daylight factor.gh (52.3 KB)
another thing not relating directly to this topic is that how can I find ill file as there is not an output named ill fills look up daylight folder in version 68 as it was in 57 version Actually I want to do UDI analyse and I don’t how can I find ill files .
@chris
