Hi everyone,
I am using new version of lark (v3) and there is some problem with SPD sky component, I receive WindowsError!
I would be grateful if someone could help me with this problem. (files needed to calculate the sky and grasshopper in the zip file)
Lark Error.zip (367.5 KB)
Hi @Soushiyant - I’m not sure if the developers of the Lark plugin check this forum. You might need to contact them directly.
That being said the WindowsError
usually happens when the script attempts to delete a file that is being used by another user. Changing/deleting the project folder might solve this problem.
