Hello all,
I have a problem loading materials from the ladybug material library.
I have created a set of materials and added them to C:\Users[USERNAME]\ladybug_tools\resources\standards\honeybee_energy_standards\constructions
When I used the search for materials component it didn’t retrieve any of the materials.
Earlier in version 1.4, I didn’t have this problem all of the JSON files in the construction folder were automatically added to the ladybug material library. Did this change in 1.5?
Thank you.
The correct path for user libraries should be:
C:\Users\USER_NAME\AppData\Roaming\ladybug_tools\standards
It changed from previous versions of LBT.
Hello,Abraham
I have the same problem.
I put the files in the folder “C:\Users\USER_NAME\AppData\Roaming\ladybug_tools\standards\constructions”, but I do not see Construction or Schedule in the components.
Can you think of any other folders, etc.
Thank you
Well, can tell from what you wrote.
The obvious one is: Did you restarted Rhino after locating the standards into the new location?
Another option is that i’m suspicious about the path you wrote. Did you copied everything into the Constructions folder? An image of the folder can help, also of the Standards one.
And the last one: What LBT version are you using? Needs to be 1.5 and above.
