Hallo everyone,
I am quite new to this forum!
I followed ALL Chris’ video tutorials about thermal simulations with honeybee (thanks a lot by the way!).
I am experiencing this problem: the attached grasshopper file seem to work but the results are not sensible at all to changes in loads and materials (i tried to put a 1m-thick concrete wall or 50 people instead of 2 and nothing changes inside!). On the contrary if I change the maximum indoor or outdoor temperature for natural ventilation, it ends up changing a lot.
Can anyone take a look and help me?
Thank you,
Irene
Simulazione Città della Pace_OK.gh (656 KB)
By “nothing changes”, you mean what result outputs, exactly?
I see you are using a nat vent component, have you incrementally tested your definition to make sure it first works without nat vent, then add it, compare, rinse, repeat?
Max
Hi Max!
Yes, I mean the Operative Temperature inside the shoebox.
I have tried with and without it and I don’t understand what is wrong. Can you see any major mistake?
Thank you very much,
Irene
For debugging issues like this you need to first check the output that will be affected directly. Does internal gains changes between the two simulation? What is the percentage of internal gain over the overall gain in the zone? and so on…
