Hey there,
I have a question about the DirectSunHours component. When using it, it worked fine on all rectangular breps that are alligned to the grid. When applying it polygonal breps or rotating the rectangular breps there some issues (seen with some samples on the image). Using meshes does not work at all.
I tried to subdivide the surfaces or use other grid sizes but it was not shown correctly.
All surfaces that where planar to either x/y/z where analysed correctly all the time also on polygonal objects.
I’m quite new so to ladybug so i guess i’m doing something wrong but I tried it several hours with different objects and didn’t find a solution. (the same problem appears also on IncidentRadiation component)
Using the 1.1.0 version on mac.
Thanks in advance,
Paul
