Am trying to open a future project epw file from my pc and the open epw file is not working when i plug it to EP. The same problem also occurs even by downloading epw file to my local pc and opening with LB.
Any ideas why this is happening cause it looks like the only way that works right now is by downloading epw files from LB website
What is the error message?
From EP there is no weather file found
Can you share the file or a screenshot? Did you check the input with a panel and made sure it is set correctly?
Move epw file to a folder with no white space.
Problem Solved, Thanks a lot
Hi Dear Mostapha
How can i open the epw file when i download it in a new version LB tools?
