Hi experts and users,
I´m trying to test the effectiveness of a roller blind product in terms of glare control. And I got the following technical data from the manufacturer, however, when I tried to interpret those numbers and get the modifier right to accurately describe the material was quite confusing.
So, I am writing this post to see if there is anyone can check if I set it up correctly.
Any insights and help would be appreciated
Thanks in advance,
/Bernard
Hi @zengwoo1028,
Did you ever manage to get confirmation of this?
Out of interest, are you able to share which manufacturer provided the data, and if you have a source for applying the coefficient of diffusion as you’ve show in your screenshot?
Charlie
Hi @charlie.brooker,
Unfortunately, it has not been confirmed. But according to the results, it seems pretty reasonable.
The manufacture of the blind fabric is called Vertisol, and the link below is one of their line-ups. Equal 3 Window Covering - Vertisol, manufacturer shade fabric
And the reference for applying those inputs are according to the Radiance Cookbook P21. And here is the like for that as well. https://www.jaloxa.eu/resources/radiance/documentation/docs/radiance_cookbook.pdf
Cheers,
Bernard
