Hi everyone!
I am totally new at grasshopper, honeybee and ladybug
I’ve been following Mostapha Sadeghipour Roudsari’s youtube tutorials, and I have a problem with my test points - I believe that the wrong data is being shown.
I know that I have connected the ‘illuminance files’ from RunDaylightAnalysis to the ‘_results files’ of ReadRADResults - which I think is incorrect as I should be connecting RAD files to it instead. I think that these RAD files should be within the ‘radGeoFiles’ from RunDaylightAnalysis, but when connecting these together I obtain a rederror message saying ‘Solution exception: need more than 1 value to unpack’.
I have updated all components and re-loaded the specific components.
I really appreciate your help - thanks in advance!
/Sara
006_Parametric_GridBasedAnalysis.gh (522 KB)
Sara,
See working file.
Needed a major updating, some replacements. But basically was almost there.
006_Parametric_GridBasedAnalysis_AY.gh (566 KB)
Hi Abraham,
Thanks so much for your help!
May I ask what you specifically replaced in order to debug it myself another time in the future?
/Sara
Hi Abraham,
Unfortunately, I do not think the problem is solved
The file you attached is the same one as you sent on your first comment.
Please use the one i sent and then let the forum know if there is indeed a problem.
As for what i replaced: basically the update process, using the LB_HB updaters, is pretty smooth. Still, there remain some components that changed the number of input/output items and there is need to reinsert them manually. Can’t recall from memory which ones i reinserted (legendPar, recolorMesh, …).
