Hello everyone,
I am getting this error when doing the energy balance. I don’t want to use the ideal air system and don’t know how to add the annual load into my code.
Can someone please help me?
Thanks/ Serina
Hello everyone,
Thanks/ Serina
Here is the answer to your question
Thanks. ^^
So will the energy number be inaccurate if this error is shown?
In my case the bathrooms and the air spaces don’t need any heating nor cooling but they do need ventilation.
yes
The mentioned ventilation is another topic.
The ideal air is just for the architectural point of view for visual representation.
When you use HVAC system (not ideal), for having data, you need to read the sql then for each sector, use LB Mass Arithmetic Operation. This will give you the required loads.
