Hello there!
I have a problem with my gh files, because they are not updated. If I use a new component it seems to be the version 1.0.0.
I know that there are components that can update components one by one, but how does it work? How do I connect them?
Also there is the Ladybug_UpdateFile component, but it fails to work with mine. (I only got it from a file I online, the one in my canvas is called _sync, but I guess they have the same function only the first one is newer, right?). The cause for the failure is descripted like this: “Failed to find the userobject for Honeybee_Generate Climate based Sky” and other components.
So the best thing would be to just update the whole canvas, but I don’t know how. Is there another component?
I use Rhino 7.
Thanks a lot!
Greetings,
Alisa
