Problem with Windows Construction Shade
Hello !! I have also been facing this issue very recently, especially after moving from 1.8 to 1.9 or 1.10.
I think there is a similar discussion about this before
Bug: incorrect referencing of window construction - grasshopper / honeybee - Ladybug Tools | Forum
In my case, I have made a construction. hbjson that I refer to for about 10k simulations, and then only change the window material in the hbjson with roller blinds. So my process also looks like this
As you can see in my base construction.hbjson: the window material is Window_U164_G06_T06. I then add the shade material BuitenzonWindowMat U164 G06 T06, reapply it using windowconstructionshd and applywindowconstr components, but this results in an error about not finding the new window material I created.
So I am not sure if this is a bug where the model-to-OSM component gets confused between the two materials.
Anyway, how I solved this is to deconstruct my base material. hbjson and create a new base construction set without any windows in it. It solved my issue.
I am not sure if this helps you, but I hope it does because the frustration is very real :slight_smile:
Prateek
