@chris I moved the topic here.
For some reason, the OpenStudio simulation fails to collect data on Tab Water. EUI outcomes of the Tab Water values. Do you know what might be the problem?
The energy+ simulation seems to collect data on hot service water but this number falls twice as high as I would expect it to be (30) and when I test to see if the number changes by assigning different programming types (as you can see in the screenshot below), the value remains unchanged. I don’t know if both problems might be related because they both relate to tab water. But I was wondering if someone might be able to tell me what the issue is.
question_energyplus_openstudio_differences.gh (184.7 KB)
