Hi everyone
I need to find a solution for Bake with the new Ladybugs tools (1.1.0 Vers): I want to export the results to Rhino, as was done with the Ladybug Legacy.
I have tried Bake directly on a Custom Preview, but the results are not the same as in the legacy version. Is there a way to Bake (WELL DONE) in 1.1.0. Ladybug version?
You can bake directly from the LBT components. Select the one you like to bake, middle-mouse and bake. It will bake into the current rhino layer. Set the viewport to Rendered view.
Works fine for me.
But, why doesn’t it keep the high colors / brightness of the preview? Results are baked darker :S
I see exactly the same colors at my end.
