Processing multiple EP results
I’ve run a bunch of EP analyses with the re-runIDF component (idfs were generated with colibri iterator), and now I am trying to process the results. I’m using the “Honeybee Normalize Data by Floor Area” component, but I’m struggling with the data structure when using multiple result files. For a single result file, the “totNormData” output will look like this:
. What I’d like to get is essentially this output for each analysis in a branch of a tree.
I’ve attached a simple example of this (requires colibri). In this example, there are 81 iterations, so I’d like final output to be a tree with 81 branches, each containing the totNormData for that iteration.
Thanks!
MultipleEP_Results.gh (565.8 KB)
This is probably much easier to be done in two steps. I think since the component does use DataTree access already to sort the results for different zones it will be difficult to load everything in one go.
I would load the results for each case and write them to a separate text file. Then load all the text files into grasshopper using Grasshopper’s read file component and you will get what you are looking for.
Thanks @mostapha. That did the trick for me. I wound up iterating through the results with a colibri iterator and then was able to get a hold of all the information I needed. Thanks!
