Hello Everyone!
First-- thank you for all the hard work. The fact that Ladybug exists is amazing.
Second-- my problem. I am trying to break up psychrometric analysis by season and by day/night, so 8 graphs total (4 seasons, 2 conditions). I am just going to do this with four separate psychrometric chart components. I can use the analysis period to block out the 4 seasons, no problem. I can also write a conditional statement using c<=0 for direct radiation to get whether it is nighttime or daytime (or something in between if I use a value other than zero). However, when I try to connect both, I receive an error:
“1. Solution exception:global name ‘getHOYsBasedOnPeriod’ is not defined”
I’ve updated my ladybug, and replaced all the components involved. I attach the file that I’m working on, and the Vienna weather data that I’m using as a test.
Thoughts or help would be much appreciated! (Under a bit of a deadline here, actually)
Alexander
Psychrometrics_day_night_problem.gh (676 KB)
AUT_Vienna.Schwechat.110360_IWEC.epw (1.48 MB)
