PV simulation by sandia model
Is there a problem when you use the sandia model to simulate PV power generation? When I use version 0.0.66 of Honeybee,I found that there is no sandia model in the PVgen battery.
IMG_4706
When using the 0.0.63 version, the input sandia model always shows an error. Could you please help me to find out where the problem is? Or how to use sandia model to simulate photovoltaic power generation in version 0.0.66.
IMG_4707
  1. To use Sandria mode you must enter a multiline panel containing Sanddia performance data see the examples
    C:\EnergyPlusV8-4-0\MacroDataSets\SandiaPVdata this component will not run until you do!
@Haobo ,
I think we had determined that the Sandia model ultimately was not supported under the hood, even though it appeared on the component in Honeybee 0.0.63. You can always edit the IDF manually and re-simulate it using the “Rerun IDF” component.
I’ll take this into account when I eventually implement PV in the LBT plugin.
