Hi the community,
I encountered a problem when running annual daylight using ‘queenbee local run’ and ‘pollination dsl run’
The errors are the same using these two commands:
how can I solve this issue?
Many thanks in advance!
Xzzz
Hey @zzzX ,
Thanks for posting the detailed logs. It seems pretty clear from the error that the core libraries are not able to find a Radiance installation on your machine. You can always check this by running the following command:
honeybee-radiance config
This will tell you all of the dependencies that honeybee-radiance has been able to find:
If you are still having trouble getting honeybee-radiance to find the installation, you can always override the default behavior by using the honeybee-radiance set-config radiance-path command.
