Question about coupling BUTTERFLY CFD analysis and HB UTCI Thermal Map
Hello to everyone,
I have a question: I’m trying to couple a CFD analysis with Butterfly and UTCI calculation with HB UTCI Thermal Map component. Is it possible to do that giving as input the list of vector that come out from the CFD analysis? Does it require a specific format for the wind speed input? I don’t know how to solve this step that try to use the CFD results to inform wind speed.
Let me explain: I have already performed a CFD simulation and extracted 6928 value for the wind velocity through the VECTOR LENGHT component. After that, I used a Python component (shared by @chris some time ago) to generate .csv file and I plugged the 6928 values on the WIND SPEED input for one hour of simulation related to HB UTCI THERMAL MAP. At the end the simulation finished without errors but I cannot read the results due to the message shown on the picture attached. Is that process correct or the wind velocity needs to be setted up in a different way?
Thank you in advance!
