Question regarding ground surface temperature simulation method
I am currently facing an issue with my simulation and would really appreciate your help.
On July 19th, although all climate parameters seem normal, the surface temperature at noon becomes lower than the air temperature. This does not happen on the neighboring days (July 18th and July 20th), where the results look reasonable.
I am not sure whether this is caused by a modeling issue or something related to the simulation setup. If you have time, could you please help me check or test the model? I would be very grateful for your assistance.
