Dear @chris, sorry if I bother you
I have a couple of doubts regarding the Annual Irradiance component (LBT 1.5)
Points 1
I noticed that by simulating the “hoy” where the sun is down (p.e. 1 January from 0:00 to 7:00), the component give a error, without any results
but if I use a “hoy” in which at that time the sun will rise (8:00) I will have (I think correctly) a 0 W/m² as value (In this case the sun rises at 8.5, according the sun-up-hours text file)
Points 2
In the annual analysis, I found negative values out from the results output
Points 3
the res_direct, take care of the w/m² only of the direct sun beam, excluding the global and diffuse illuminance?
In this case, also the “visible” input, decides if the annual irradiance takes into account only of the direct solar rays, for the all output result (peak, average and radiation)??
Thanks for all and a good Weekend
