I have worked with DIVA for Rhino and already tried DIVA for GH, but I just started. Now I want to use Honeybee for more controlled simulations. In DIVA for GH there is no problem using the material from C:\DIVA\Daylight\material.
In Honeybee I wasn’t able to import this RAD file. I had to add every material with the addtolibrary component.
Yesterday, HB told me about the new version, so I’ve done the update. Looks like there are some very helpful new tools… but I can’t get HB to fly (Ladybug flies).
The addto/callfromlibrary component says:
Solution exception:honeybee_RADMaterialAUX
Never had this Problem before and I don’t know how to solve it.
Have you changed the source code? By default Honeybee should not be importing materials from Diva.
In honeybee you can copy all your custom materials to (ladybugFolder\HoneybeeRadMaterials.mat). Make sure to leave an empty line between each two materials.
Back to the error if you upload the material.RAD file here I can tell you why Honeybee can’t import the material from your file.
I tried the file and I can’t recreate the problem. It imports all the materials with no issues. Can you try the attached file and let me know if it works for you?
Mostapha, I tried too and I couldn’t recreate it either…by the way, do you know why is Honeybee reading the file Material.rad from C:\Diva\Daylight in the first image ?
Thanks Jacob for reporting back. Can you share with me the initial file? By checking the line numbers we should be able to find why this issue is happening at the first place.
