Wanted a little help with a radiation study wasn’t sure if I was going about it the wrong way. The attached ladybug file generates a correct ( I assume ) radiation map but when I add the solar shades, as the context, it seems to not calculate the radiation correctly. The radiation then reads as a consistent gradient across the façade. I use the shades as the context in the analysis maybe there is a better way to go about this study, do I need to adjust the grid size? Any help would be appreciated.
NEIU radaiton.gh (79.9 KB)
