Radiance Installation
  1. Solution exception:The installed Radiance is not from 2020/9/3 or later.
    Download and install the version of Radiance listed in the Ladybug Tools compatibility matrix
    1.4 Compatibility Matrix · ladybug-tools/lbt-grasshopper Wiki · GitHub
This the error which i am getting even after installing the latest version of Radiance which is mentioned in the error.
See here:
@chris I am also getting the same error. I did update using LB Versioner, still. Kindly advise.
@chris @shubham09
It is possible that in multiple locations Radiance could be installed, we need to check and ensure that. Especially in “username\Ladybug Tools”. This is for information.
Yes, maybe you have multiple versions installed. You can always use the HB Config component to see where Honeybee is loading your Radiance from. And you can use the HB Check Versions component to see what the version of that Radiance is.
