I’m trying to calculate annual glare for a Rhino view, I assigned ashik2 radiance material, but I keep getting a message “fatal error reading line 511”. When I replace this material with plastic I don’t get any errors?
Any thoughts!
Any thoughts!
What is exactly ashik2 material?
Hi Mostapha,
You can find more info about the ashik material in this link
http://www.radiance-online.org/community/workshops/2012-copenhagen/…
Now, the simulations work fine, but after careful look at the .rad file, I found out that the material ashik2 isn’t passed to the .rad file generated by Honeybee. I doubt that it’s Honeybee’s fault, simply because I’m having the same problem when I use DIVA as well.
Did you try to use it with point in time simulation? This might be a limitation of Daysim which doesn’t support this material type.
