2- Where is the HB .rad file located? I prefer to add Radiance materials directly in the .rad file instead of using the add Radiance material component.
Look for “HoneybeeRadMaterials.mat” in Ladybug’s default folder- You can also use “Honeybee_Add to Radiance Library” component to write your materials to the same file.
is there a possibility to change the default values for zone-surface?
If i define a material e.g. EXTERIOR_ROOF and add this like described above, the calculation uses the predefined values if i don’t use HB_setRADMaterials and assign the new values.
In Germany we have a directive concerning daylight-factor calculations with fixed values for reflectance, therefore it would be great to define this values as standard for all my calculations…
Can you help me to understand why does using setRadMaterials component do not work for you? You can assign any radiance material that you want to the surface.
using setRadMaterials works fine but it would be great if the default values could be defined e.g. with an ini-file. This would allow us to use the standard values from the regulation without assigning them to each zone manually. Not a big deal at all but nevertheless a possible source of error for the users.
Hi Julia, A quick note [for advanced users]. A good practice is not to use Glass as the material name. ‘glass’ is the radiance modifier name for transparent material. It will work but it’s just not a good practice.
