I encounter this error ; 1. Solution exception:Failed to load the results form an empty file: D:\matrix\untitled\gridbased_annual\result/scene…default.ill Double check inputs and outputs and make sure everything is run correctly.
when I input the Radiance Parameters to simulate the annual daylight in Honey Plus
. But when I run without the Radiance Parameters, the error goes away.
I also read this topic.
Given that I am using Radiance version 5.2.1 ; Again, the reason for the error could be the radiance version???
I also tried removing the gridbased folder from the matrix file each time and I ran it; But there are still errors.
And I’m really confused and thank you in advance for your help.
