Radiance simulation
hallo , I am new to GH and learning its different tools. I followed a you-tube RADIANCE example , and twice I reached to the point to activate the HB annual daylight , but it keeps on calc
ulating and in the end it crashes.
in the pictured attached , basically I stops when I click the false to true boolean toggle.
Hello @tanyas
I don’t have a full overview of your script but, from what I see, the problem is that you are using a wrong component to set up the grid for daylight simulations. You are now using the “HB Radial Grid from Rooms”, which is typically used for glare studies, while you should use the "HB Sensor Grid from Rooms (see picture attach). Switching them should solve your issue.
Matteo
