I am running a solar radiation analysis on a simple script with horizontal inclined louvers.
I would like to find what is the best angle (genome) that generates the maximum total annual radiation (fitness) - using galapagos.
Even after limiting the angle slider range between 40 & 50 degrees - in order to reduce the processing time - when I start the solver, I can see the panel angle changing, but with no results.
Any help?
Attached the grasshopper script and a screenshot.
Many thanks!
Elias
