Hi, i want to simulate the radiation analysis on a surface behind a type of shading(a pattern). I want to know if is it accurate to use Ladybug-sunlight hour analysis? or should i use Honeybee to get accurate results.
Here is a photo and i want to simulate something similar to this but i could not find the main component.
Thanks for your help.
Hi @Nimafo thanks for your reply
I have tried both LB-Radiation Analysis and HB-daylight analysis and the results were slightly close. I just wanted to know which is more accurate.
The LB_RadiationAnalysis accounts only from direct and diffuse sky radiation. HB_DaylightAnalysis CAN account for those two + reflected surfaces … but you need to set the proper parameters for that.
