Hi, i want to simulate the radiation analysis on a surface behind a type of shading(a pattern). I want to know if is it accurate to use Ladybug-sunlight hour analysis? or should i use Honeybee to get accurate results.
Here is a photo and i want to simulate something similar to this but i could not find the main component.
can you please help me with this?
Thank you
@mahyafani I have upload a example for solar radiation under the tree effect. Maybe this example can help you.
http://hydrashare.github.io/hydra/viewer?owner=ymg2007&fork=hydra&id=Modeling_Tree_In_Radiation_Analysis__Using_Two_Methods
