I have installed ladybug and honeybee plus Radiance and Daysim on WIndows 10. Yet! when I tested the radiance analysis the selectedSkyMtx component gives me keyerror 1, and the tested geomerty shows no radiation.
EPW file is correctly connected and my working directory is under C:\username\appdata\roaming…
Have manually set the raypath and path in the Env.User Variables(EUV) and Env. System Var. (ESV)to
Go to C:\Users\Nia\AppData\Roaming\Ladybug. There should be a file named gendaymtx.exe
Right click on the file and select properties. Make sure the file is unblocked and then try again. The fact that mtx files are 0 KB shows gendaymtx hasn’t been executed correctly.
You can download the file from this link. Make sure to unblock the file and replace it with the current file. Alos make sure to set useOldRes to False. In your screen capture nothing is connected to the input.
If this didn’t solve your problem give me some time to update the component and write a more robust checking process to help you solve this problem.
Would be great if there is a more elegant way to do the analysis without switching the protection. The exception app in the firewall was not enough. I needed to switch it entirely.
Had the same problem. I was able to solve it by replacing in my directory the gendaymtx.exe file provided by Mostapha and by toggling false the useOldRes files.
