I exported the four radiation diagrams of the building in different months, but the value and color are not unified. For example, 242 is orange in the third diagram but it is light green in the second diagram. So I wonder how to unify the values in one color strip.
Thank you.
Hi @Professor_Jobs, you can use legend parameters component to set the higher and lower bounds for the legend.
Hi mostapha,
Thank you so much, it solved my problem perfectly!
