Why the values of the radiation rose and the radiation sky dome is so different? In my head, they should be the same
Radiation rose shows the radiation values for a face with a fixed vertical angle (the default is a vertical face) from different orientations. The Radiation Dome does show the radiation values for combination of different vertical and horizontal angles. You can think of the Radiation Dome as a 3D version of the Radiation Rose diagram.
Hi, Mostapha. English is not my fort but let try to explain better my problem. I have this building (figure 1) with 58.5 m² and I am receiving more than 27.11 kWh/m² and I can’t explain where this radiation comes from if the maximum radiation that the radiation gives to me is 9.96 kWh/m² for the same period.
