Hi Abraham,
The length shows the magnitude of radiation form each direction but the thickness of arrows is just an arbitrary relationship between the length of the arrow and the scale. It doesn’t show anything special. I found the default value based on annual runs and that’s why it doesn’t give you a good graphic for a single day. I should fix it for the next release to work for both cases.
Meanwhile you can manipulate the number in genRadRoseArrows function in Ladybug_ladybug component and find the right relationship for your study.
There is a line as: ptMoveDis = 20 * internalSc
Change it to: ptMoveDis = .20 * internalSc
let the modified version of Ladybug fly and re-run the radiation-rose. It should give you an acceptable graphic.
Thanks for reporting this and let me know if it didn’t work so I can send you the modified version.
Mostapha
