It must be something simple but I’m struggling to figure out why I cant seem to generate a proper Cumulative Sky Matrix cumulativeSkyMtx.
The image and the file should be pretty easy to read.
Ladybug_Struggles.gh (76.8 KB)
And the solution appears to be giving the workingDir_ input for cumulativeSky component to be the file path C:\Radiance\Bin\
Hi Nico, Happy to hear you found the solution yourself. Setting up working directory to any folder that you have full access to it should solve the problem. -Mostapha
