The surface by surface daylight analysis script supplied is where I’ve tried to analyse a brep and it seems to only want to analyse one surface, disperse the test points in an awkward manner, and finally give no result.
@devang
Restarted and still failing… system goes down with Not Responding and cmd reports this. Is it anything to do with the location of the files? They’re all on the C Drive as advised
this is all I get from the result too, also to mention I’ve checked the direction of the normals that are correct. should be the whole envelope and not just one surface?
A) why/how do I need to rotate it? Do I need to suggest where north actually is somewhere else in the script?
B) I assume all I had to do was run the script and I would see as your screenshot? If so, then mine doesn’t produce any results, just the baked geometry…
