I am having an issue where all my ladybug components will regularly stop working and I will get a “Failed to Import Honeybee” or “Failed to import lbt_recipes”, etc. error message on all my components. Sometimes when I un-install and re-install ladybug it will work again, but not always. It will work for a little while and then randomly stop working. I have added the correct path to “Edit Python Script” in grasshopper, so my path is correct and should not be the issue. I hope this is clear, let me know if you need me to clarify any parts of this issue. I have also run the .bat file with rhino closed.
