Dear @chris,
sorry if I bother you.
I want to ask you if there is already a component that makes the sum of the annual radiation between all sensors and gives how many kWh/m2 the surface receives, regardless of how many sensors are analyzed.
Why out from the HBAnnualCumValues I have the annual sum of the radiation for each sensor, and adding the GH native mass addition component, then gives me the total sum of all sensors, but if I have the same surface analyzed, one with 150 sensors and one with 300 sensors, obviously I have a greater value.
Thanks and best regards
