Recipe "Annual Daylight" is not installed
Hi, everyone! I started to use Ladybug and Honeeby with the new version 1.2.0 for Mac -I’m beginner- (Rhinoceros 6 + MacOS 13.14 + Radiance 5.3). When I try to run a file example " annual_daylight.gh", I see this notification “Recipe “Annual Daylight” is not installed”. What can I do? Thanks
You are using a component with version 1.2.2 but I am pretty sure that you have the core libraries of the 1.2.0 release. Running the “LB Sync Grasshopper File” component in that Grasshopper definition should sync the components on the canvas with the version of components that you have installed. Then, everything should work.
Thanks @chris!! Now, it working!
