Hello again,
i have a problem with my simulation environment. I am using ladybug and honeybee in python only and so far everything worked fine. Now i installed ladybug for Grasshopper as i had to test a model inside Grasshopper.
But now my python setup is not working anymore when running the Annual Irradiance Recipe, where i get a PermissionError. When i looked into the log-file from the Recipe is saw that it looks for the lib files inside the C:\USER\ladybug_tools\python\lib folder and not in the .venv folder of my python environment.
I guess the set_python_path.bat file changed some environmental variable. Is there a way to change it back? Or more general, is there a ways to use ladybug_tools in Grasshopper with the installed Version from Food4Rhino and use installed packages from pip at the same time?
Any help appreciated ![]()
