I wanted to know if is is possible to use the operative temperature results from a simulation as the input for the natural ventilation schedule which is placed before the simulation. The error occurs saying there is a recursive data stream and the component depends on itself. Is this even possible to do?
For context, the operative temperature results output (on the right) would be input into a component I made (which creates an automatic ventilation schedule), then input into openingAreaFractionalSched_. A loop basically.
Thanks.
