I am working on a project that will Build a glazing façade inside a stadium and next to a football field.
Because of that we are in a moment of form-conceptualise for this façade in order to achieve a better environment inside and most importantly outside. Because games can occur at hours like 4pm the reflection could not interfere or disturb principally at this time.
Until now i found only a way to use Raytrace in order to perceive the path the sunrays will take on the glazing if the system stays straight. However I am still trying to find a way to analyse the extra radiation and heat that this façade will add to the field and the grandstand.
I already checked the microclimate tutorials at hydra and other videos about rad material although none of these had clearly helped me thorough this. Hope someone here could help me find a solution for this.
Many thanks in advance.
